It is currently September 24, 2017, 3:28 am
Post new topic Reply to topic  [ 7 posts ]
 Post subject: Re: P.H. Webcam frustration
Unread postPosted: June 19, 2017, 11:51 am
Just tried it on my basement computer which has Windows 10 and at first I got a pop up about the site uses Java but, after I clicked on a few things I was able to get the camera to work fine for me. Have yet to try it though on my upstairs computer which uses the Windows 8 format so hopefully the camera will work fine on that and Oh Yeah, forgot about my I-pad as well which I still have to see if it works on that as well. Hope this helps and Good Luck all.
Unread postPosted: June 18, 2017, 10:38 pm
I also have Java related problems trying to access the site (using the link listed below) using Microsoft Internet Explorer under Windows 10.
BUT, I have no problem accessing it using the Google Chrome web browser on the same PC (it also works fine in Firefox).
Why not just install Google Chrome (it's free)? You don't have to set and use it as your default browser if you don't want, but I believe most people are doing so these days (2017).
Expecting one web browser to be able to access every site flawlessly is a bit of a stretch, that's why I have ~8 installed at any given time.
Unread postPosted: June 18, 2017, 11:09 am
Thanks for trying but my Java settings -- despite this site being noted as an exception -- will not allow access.
Unread postPosted: June 18, 2017, 7:39 am
Just accessed cam on this : http://www.porthuron.org/AVRiverCam.aspx
Unread postPosted: June 17, 2017, 10:35 pm
Seems to be working fine for me. Just watched the Calumet and Spruceglen pass by downbound.
Unread postPosted: June 17, 2017, 7:52 pm
Do not adjust your set. The cam is down, probably long term.
 Post subject: P.H. Webcam frustration
Unread postPosted: June 17, 2017, 7:36 pm
Ever since installing Windows 10, I cannot access the Port Huron web cam. I've reset Java security, but even though the address is allowed, I get the "blocked for security reasons" message.
What else can I do?
Personally, I'd like to see a web cam system like at the Dossin Museum or at Two Harbors and the Duluth area.
