Speer's record load
Re: Speer's record load
The Stewart J. Cort and Presque Isle could me modified to increase their mid-summer drafts to take advantage of recent increased water depths, but this has never been done.
For example. the Cort's draft could be increased to 32-feet 6-inches if deck strapping was installed. Similarly, the Presque Isle's draft could be increased to 30-feet 3-inches, again if deck strapping is installed.
I'm surprised the other BayShip thousand footers haven't broken any records yet (American Integrity, etc). Or are the other operators being more conservative?
Funny how CSL failed to mention the CSL Laurentian running aground at Nanticoke on August 30, 2017 with another of these record loads. Refloated that evening with an off-load into LLT's Mississaugi which turned back while upbound above Long Point to accommodate the request for empty vessel. Wonder if TSB even knew.
With the high water levels it would have been interesting to see what types of tonnages would have been shipped from Escanaba this season.
Well the Gott has departed Two Harbors recently for another trip to Gary, Indiana. With new cargo records being broken at the Soo with the Speer in late July and the Gott last week, could we see be seeing yet another record with this next load by the Gott? Should be very interesting to see and find out what the tonnage is on this very next load they are taking to Gary. Might we top out at 74,000 tons on this load? I don't think that we are too far away from it! Time will tell.
Ohio Bob wrote:With records being broken at the Soo, and water levels holding high, it lead me to think about the new lock proposed at the Soo. Are they proposing to match the Poe Lock's dimensions or would they consider increasing its depth over the sills?
The Poe's sills are not the limiting factor, the rock cut is.
Ohio Bob
Unread post by Ohio Bob »
Greenshirt
Unread post by Greenshirt »
Guest wrote:The controlling issues at the locks are the water over the sill getting into the locks, the water level in the pool below the locks, and the water level in rock cut. At mean low water datum the depth over the sill is 27'5". The depth of the lower pool is 26'11". Rock Cut is 26'11". So depending on water levels above MLWD you can determine how deep to load. Wind direction and atmospheric pressure affects the water levels, so the ships have to be very careful about how deep to load or be forced to anchor to wait for water levels to go up if you loaded too deep.
This is the secret to the success of shipping companys, how deep can you go in the St Marys! While this in the past was the secret of captains its often guided by head office now. At least one company used 27'6" at chart datum for above the lock and the rock cut. That leaves about 9 inches from what the surveys say. This week Lake Superior is 23" and Lake Huron 37" above chart datum. So the Speer at 29' 6" was inch deeper than that formula. Maybe took advantage of favorable winds and water fluctuations[/quote]
Boy I'd love to stick a go-pro to the keel of one or these boats and a light and watch just how close that is!
The Speer's record load was recently broken by the Gott. It hauled 73,940 short tons on September 6.
The controlling issues at the locks are the water over the sill getting into the locks, the water level in the pool below the locks, and the water level in rock cut. At mean low water datum the depth over the sill is 27'5". The depth of the lower pool is 26'11". Rock Cut is 26'11". So depending on water levels above MLWD you can determine how deep to load. Wind direction and atmospheric pressure affects the water levels, so the ships have to be very careful about how deep to load or be forced to anchor to wait for water levels to go up if you loaded too deep.[/quote]
Guest wrote:The draft would have been around 30 feet. She can haul 191.4 net tons per inch. I wish the USACE would have reported the draft besides the amount of iron ore carried on the Speer's downbound transit through the Poe Lock.
Draft at the Soo is limited by the water depth in the St. Mary's river and the depth of water over the sills at the Poe Lock.
The Poe Lock has a depth over the sills of 32 feet, but obviously the depth over the sills was deeper than that due to the greater volume of water in the river.
If the St. Marys river was ever deepened, it would be to the 30 foot depth.
draft was 29'6"
In the Fleet Gallery it says: "The Speer's 20 hatches feed 5 holds where she is capable of carrying 73,700 tons at her maximum mid-summer draft of 32 feet 1 inch."
If her cargo was 73,875 then wouldn't her draft be over 32 feet 1 inch ? How does this reconcile with the various limitations along the route (i.e depth over sill in the Poe, Rock Cut, etc..) ?
her record was NET tons. The 73,700 figure for her max load line is in GROSS tons.
The 73,700 tons listed on the Speer's description page is in gross tons, while the record cargo she carried in July was in short or net tons.
draft was 29'6"
If her cargo was 73,875 then wouldn't her draft be over 32 feet 1 inch ? How does this reconcile with the various limitations along the route (i.e depth over sill in the Poe, Rock Cut, etc...) ?
hausen
Unread post by hausen »
CSL Laurentien's record load, as reported by the CSL World newsletter:
She loaded 34,337 metric tons of iron ore pellets at Superior, WI's BNSF Dock #5 on August 13, 2016 with a destination Nanticoke, ON.
(This is by far the largest cargo carried by a Canadian ship from Lake Superior to the lower lakes; up until just a few years ago a similar record cargo would've been in the 29,000 - 31,000 metric ton range.)
Draft was 28' 10.5" fwd, and 29' 02" aft.
Ship's officers monitored water level trends for weeks in advance, and closely watched weather conditions and fuel consumption as they carried out the voyage. They transited the St. Mary's River with water level at +32", and transited St. Clair and Detroit Rivers with water levels at +45".
draft was 29'6"
a boatnerd wrote:When the Edgar Speer set a new record load of iron ore,how much deeper was her draft? What would her ballast draft be? Also at 60000 tons of cargo,70k? What is maximum draft to get thru the Soo locks? Thank you in advance!!
Not 100% sure but thought in the oast when I've gone to the Soo with my folks, the set draft was around 27-28 feet loaded this is of course depending on the water levels and how much water I think the dams or compensating works release I think if I'm right here on this? Surely someone else will know more on this than myself. Also this is nit being made much in public but, the Speer's record load also just surpassed the Burns Harbor which in 1996 I believe it was at that time anyway, set the record for the Soo at over 72,000 ton through the locks. You can find this out I think on the facts and figures part of this website through the homepage here. Speaking of record loads, they must be very secretive and protective of these records along with the tonnages involved. Some of the old records on the Facts and Figures part of boatnerd has not been updated as far as tonnages in many years. Take for instance the CSL Assiniboine has set records for the largest load I think carried out if Thunder Bay in the past year or so and I think the cargoes were either grain or coal? It is listed in the CSL newsletter. The CSL Laurentien also carried a record cargo at some point in the last year or so of ore to Nanticoke and their new Trillium Bulk Carriers have also set tonnage records as well loading from Thunder Bay last year. Surely the Equinox-class vessels from Algoma have to be setting some records as well that I'm not seeing or hearing about. With the higher water now on the lakes and rivers, I'm sure that many ships have been loading deeper loads this year. Sorry for the long response but I hope that this helps you out some.
a boatnerd
Speer's record load
Unread post by a boatnerd »
