It is currently February 17, 2018, 8:09 pm
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Re: Footer HP question
Unread postPosted: November 15, 2017, 11:49 am
yes, it's due to conflicts at the loader. I rode the Gott to Conneaut and back and on the return, we crossed Superior on one engine due to availability at the shiploader. I guess why burn the fuel at design speed just to "hurry up and wait: at the breakwall.
Unread postPosted: November 14, 2017, 10:10 am
I noticed Monday the Gott cut back to about 6 knots for about 7 hours heading into Two Harbors. This got it there just as the Baie Comeau was leaving. Could this be to save on fuel to do this rather than run 12-13 knots and if so how much might this save?
Unread postPosted: November 13, 2017, 11:37 am
DanMD wrote:
Why do the Gott and Speer have over 19,000 HP but show a slower speed than the other Footers with 14,400 HP according to "Know Your Ships"?
It should be noted that speeds listed in Know Your Ships might be a top rated speed, which is kind of an arbitrary number and as a ship's power plant ages, becomes more and more of a theoretical bit of notation than anything that has much relation to actual vessel operations.
If you monitor actual open lake cruising speeds on a service like marinetraffic.com for a few days, you'll notice that a ship like the Gott, with higher horsepower and a much newer power plant, typically moves a little faster than, say, the McCarthy or the Indiana Harbor.
Unread postPosted: November 13, 2017, 11:08 am
I seem to remember it was extra horsepower for getting through the ice.
Unread postPosted: November 13, 2017, 9:43 am
I'm no engineer, but I think a good part of that is the cargo. The Speer and Gott were designed for iron ore, while the others were built to handle more mixed commodities, and iron ore is a lot heavier. It could be that the Gott and Speer have more torque, which doesn't always equate speed. But, I could be way off base on this. Just a thought. It is also generally true that ships don't run full power either, because that is not fuel efficient and is bad for the engine.
 Post subject: Footer HP question
Unread postPosted: November 12, 2017, 8:21 pm
