It is currently February 20, 2018, 4:35 am
Post new topic Reply to topic  [ 9 posts ]
 Post subject: Re: Benson Ford / Ford vessels movie 1920s
Unread postPosted: November 22, 2017, 7:15 am
Rob W wrote:
Has anyone ever found a recording or video with sound of those big doxford engines running? Everyone always talks about their "Makin'-Money Makin' Money" sound but I have never found it.
I kept trying to turn up my volume to no avail
Easy to find on youtube complete with sound. Here is one, there are others there as well.
https://www.youtube.com/watch?v=4znT5lsejhs
Unread postPosted: November 21, 2017, 10:01 pm
Unread postPosted: November 15, 2017, 5:36 pm
Ford operated two Huletts from 1922 to (1944)1956. The first machine was knocked over by the ill-fated Carl D. Bradley in 1944 and the second machine was dismantled in 1956.
The Huletts generally caused less damage to hatch-coamings then the clam-shell buckets, as they were easier to guide into the hatch openings. The clam-shell buckets and bridge cranes allowed the ore to be moved a farther distance from the dock to the furnace yard, whereas Huletts would drop the ore to a pit, from which the ore was moved by bridge cranes to a stockpile or the furnace yard.
In the case of Bethlehem Steel in Lackawanna, New York, their Huletts had extensions on the ends of the machines, upon which were installed conveyors so the ore could be stockpiled further from the dock, than could be done with a conventional hulett.
Unread postPosted: November 15, 2017, 4:21 pm
Unread postPosted: November 15, 2017, 12:16 pm
[ How long did Ford operate Hulletts before switching completely over to clamshell buckets? *] I believe it would be the other way around: Hulletts taking over the clamshell buckets.
Unread postPosted: November 15, 2017, 9:07 am
Interesting to see the Benson Ford being unloaded by a combination of Hulletts and clamshell buckets. How long did Ford operate Hulletts before switching completely over to clamshell buckets? What were the advantages of the clamshell over the Hullett?
Unread postPosted: November 15, 2017, 7:25 am
Is there a Hullett unloader still intact and set up anywhere?
Unread postPosted: November 14, 2017, 11:06 pm
Great Hulett unloading action in this one if you've never seen these unloaders at work.
 Post subject: Benson Ford / Ford vessels movie 1920s
Unread postPosted: November 14, 2017, 8:18 pm
After viewing a link to archive.org provided in another post, I did some searching and came across this interesting video clip of the Benson Ford and Ford barges from the 1920s.
https://archive.org/details/FordLakeShippingCa1927
Hopefully there are more Great Lakes shipping oriented subjects on the site!
