Hull Painting
hugh3
Re: Hull Painting
Unread post by hugh3 »
After painting of hull the dry dock is filled and boat is moved on the blocks to facilitate paining whole bottom.
Not Tut
Hull Painting
Unread post by Not Tut »
When a ship is in dry dock it sits on a set of blocks after the water is pumped out. If the hull is painted are the areas of the hull that rest on the blocks left unpainted or is there a way of moving the blocks in order to complete the job. Thanks…
