It is currently May 26, 2022, 9:20 pm
Post new topic Reply to topic  [ 13 posts ]
 Post subject: Re: Wilred Sykes
Unread postPosted: April 1, 2021, 8:56 pm
These loads out of the BNSF usually go to Burns Harbor.
Unread postPosted: April 1, 2021, 8:24 pm
A correction to my post from earlier as I see now on Harbor Lookout that she is now due at Superior to load on Sunday at 8:30 a.m. at the BNSF Ore Dock.
Unread postPosted: April 1, 2021, 6:54 pm
Anything mentioned on where that load may be going to? It is not too often they load in Superior. I see on Harbor Lookout's website though, they are scheduled back up to Two Harbors to load again.
Unread postPosted: April 1, 2021, 1:43 pm
The Sykes will be loading ore in Superior sometime soon, according to their official Instagram account
Unread postPosted: March 30, 2021, 5:34 am
Well, the Sykes did load its first cargo of the 2021 season at Two Harbors. I doubt that it will spend much time in the ore trade as is it a little small to compete against the larger carriers involved in that trade? It will be interesting to see if Cliffs becoming involved in its operation has an affect on its usual trading patterns.
As seems to be the trend for the Sykes the last few years now, she does 1-2 Lake Superior trips in the spring then returns to her normal Lake Michigan stone and slag runs until the end of the year when the stone docks close, then at that time she may do another few ore loads. With Cliffs in the deal now, that may change.
Unread postPosted: March 29, 2021, 6:07 pm
Unread postPosted: March 25, 2021, 9:58 am
Thanks Garbear & Denny, hope she is still coming to Two Harbors and her destination doesn't change. Hope to be in Two Harbors when she gets there.
Unread postPosted: March 24, 2021, 4:09 pm
Sykes is underway in Green Bay
Unread postPosted: March 24, 2021, 2:28 pm
They are leaving Sturgeon Bay as I type this now. Hope this helps out!
Unread postPosted: March 24, 2021, 1:47 pm
Thanks for the update, Denny. I wasn't aware of problems with the Sykes. Yes, those departure & arrival times are not to be taken with a lot of confidence. Gale warnings were up on Lake Superior last night, things appear to be calming down a bit now.
Unread postPosted: March 24, 2021, 10:12 am
Ed, check out the thread for Sturgeon Bay departures just below here a little bit. There’s mention in it that the Sykes had a mechanical problem of some sort and they’d be delayed upon departure. Once they have the problem fixed then they will be departing at that point. Also I wouldn’t go by the Harbor Lookout site too for ETAs as you never can tell as far as with the weather. We’re supposed to see and get high winds here in the Detroit area this weekend so, I’m sure that will slow things down and cause some delays. At any rate, just happy to see the ships return and the start of the new season. Take care be safe and all the best to you in 2021!
Unread postPosted: March 24, 2021, 9:25 am
Ed wrote:
Does anyone know if the Sykes has left winter layup? Scheduled for 7:30 am on Friday in Two Harbors but no mention that she has sailed on the layup list nor can I find her on the AIS map.
Under Sturgeon Bay departures it says she had mechanical issues and will depart when fixed.
 Post subject: Wilred Sykes
Unread postPosted: March 24, 2021, 8:25 am
