GLF update?
Re: GLF update?
if glf losr or looses the uss contract, and the blough can only unload at 2 ports, really whats the need to repair her. next stop? port colborne
Re: GLF update?
the widest beam on any canadian lake boat, sailing or layed up is 78ft. even mckeil marines barge "huron spirit" has a beam of 80ft and cant go below port colborne. even interlakes new build has a beam of 78ft. why? so if necessary it can use the welland canal and/or st lawrence seaway
Re: GLF update?
Unread post by GuestfromEU »
Hausen, you raise good points. The Roger Blough has original Pielstick main engines and three out elderly generator engines out of four. With two tunnel belts passing through the engine room, it may be challenging to fit a scrubber and associated machinery, which will not offset the new EEXI and CII requirements regardless. Re-powering is an option, though likely cost prohibitive. Would re-powering have an attractive return on investment? Considering the CII requirements become more stringent year-over-year, many older ships face a losing battle as the numbers will not work. Is it a sound decision to invest $5-10 million for re-powering and upgrades when the ship would fall below CII requirements in 8-10 years (or less)? The ultimate goal of these new regulations are to force shipowners to adopt alternative fuels and other green technology like solar panels, sails, or other options yet to be identified.
You prosed an excellent comment in that future, rapidly approaching changes to the Great Lakes fleet may be hard to envision in 2021, but will come nonetheless. Decisions are still not firmed by shipowners on paths forward, but options are few and limiting, whether practically or financially.
While I may sound like a Debbie Downer and beating this topic like dead horse, this is a subject I am involved in on a daily basis with ocean ships trading in the Australasian market. Not the Great Lakes of course, but the new regulations affect all in the same. The Great Lakes ship watching community has a following not matched by many elsewhere in the world. This is a reason I visit this page frequently. Unfortunately, devout followings often do not accept reality in some aspects. While the best outcome is to see exemptions for ships on the Great Lakes, it is doubtful to happen and we cannot predict what the US or Canadian fleet will look like in 3, 5 or 10 years from now.
Re: GLF update?
Guest wrote:When it comes to being in the know regarding office decisions, crew are Very low on the totem pole.
Oh just gotta love the second guessers. I’ve known my friend 40 years. Sailed with him. Not a scuttlebutt spreader. He’s VERY high on that totem pole. Clear? BLOUGH has 2 ports it can serve. No backhaul capacity. When they fixed it after the grounding zug island was still making iron. BLOUGH is damaged extra tonnage. Anything is of course possible but doesn’t mean probable. Wait n see
Re: GLF update?
I was under the impression Rand wasn’t running the ASC footers? I thought they only took over the river boats.
hausen
Re: GLF update?
Unread post by hausen »
ML wrote:Did CN lose hauling contracts with US Steel to ASC? Seems like the last few years ASC's footers haul to Gary and Conneaut and am wondering if that has any play in CN layups and the Blough's fate..
It probably does have something to do with it - word on the waterfront seems to be that AIP/Rand is running the ASC footers with notably small crews. If that's so, it likely allows them to charge lower freight rates in the short term, even if it means ASC vessels might end up with shortened life spans in the long term from the deferred maintenance and increased wear and tear that a very small crew might lead to.
In the short term this might mean that ASC is able to charge lower freight rates than GLF. Given how some of GLF's ships were built and how they've been maintained, some of those GLF ships are likely to last much longer than most ASC ships, however.
The big looming variable is what happens with new shipping industry-wide fuel efficiency standards coming from c. 2023 onward, which might make for some unpredictable outcomes in the business of Lakes shipping which a lot of us in 2021 might think of as very unlikely.
ML
Re: GLF update?
Unread post by ML »
Did CN lose hauling contracts with US Steel to ASC? Seems like the last few years ASC's footers haul to Gary and Conneaut and am wondering if that has any play in CN layups and the Blough's fate....
JMarx
Re: GLF update?
Unread post by JMarx »
I'm probably the least qualified to comment, but if they have excess capacity it would make sense to let the Blough go and focus investment on their other Lakers. Footers aside, they have Munson, Anderson, Callaway, and Clarke...my understanding is that these ships are very similar and/or sister ships...this provides economies of scale and operational capability to easily dispatch interchangeably. And for the biggie loads, they have the footers. Was the Blough serving a need that couldn't be met with the smaller/bigger ships?
I'm not in the industry so perhaps I'm missing some nuance... hopefully I'm all wrong...
Re: GLF update?
guest wrote:with 2 105 ft wide vessels done for, is that new lock at the soo justified?
Yes, the new lock is justified. The ships with a 78-foot beam also need to use the Poe Lock and the new lock when it's completed. If the Poe Lock is out of service for any length of time, it means that ships with a beam of 78 feet or wider, and a length greater than 767 feet can't use the MacArthur Lock. That's a vast majority of the American lake fleet, and a number of newer Canadian vessels laidup.
As for the Blough, I'm still waiting on the NTSB investigation report to be available.
Andrew
Re: GLF update?
Unread post by Andrew »
Based on the fact that GLF has essentially been running a fleet of 6 this season without any real issues, and keeping the Clarke at the wall, seems to indicate that they're not in a position where they see themselves needing that tonnage anytime soon. Frankly, they could take the money and put it into the Callaway and Clarke, since the stone trade has been very good the last several years.
One has to wonder if CN is considering slowly divesting their maritime operations if the Callaway and Blough never get back on the lakes. Time will tell, I guess. The loss of the Blough would be crushing for boatwatchers, but with that St. Clair-esque size, it really is too big to haul stone and too small for the footer-size loads.
Re: GLF update?
Bob
Re: GLF update?
Unread post by Bob »
So now what do they do with the blough if she’s done send her to scrap?
Re: GLF update?
Re: GLF update?
My friend is definitely not low on the totem pole. Well respected long time GLF mariner. He says Blough is finished I believe him. Said damage is real extensive. Too expensive too repair considering market outlook n limited flexibility.
Re: GLF update?
Guest wrote:For all of you speculating about the BLOUGH. Spoke with long time GLF officer in my home town on Saturday while he’s off his ship on vacation. He says the BLOUGH is finished. Won’t be repaired.
Heard the same thing several months ago with a few of the shipyard workers who told me she was done. However NO decision has been made public and the information provided to me was by low men on the totem pole.
Chris M
Re: GLF update?
Unread post by Chris M »
Spoke with someone currently working with GLF and nothing offical has been decided but it's not looking good
Re: GLF update?
Re: GLF update?
What year was the Hugh?
hugh3 wrote:I remember on the USS boats that I sailed on.
hugh3
Re: GLF update?
Unread post by hugh3 »
I remember on the USS boats that I sailed on there being a notice on the pilot house bulkhead about insurance. As I remember it stated that USS would cover the first 50% of any cost and Lloyds of London would cover the second 50%. It had to do with a fund that USS maintained instead of paying 100% of premiums.........
Re: GLF update?
All GLF vessels have P&I coverage with North of England, as I can see from online P&I Club database search. H&M search is not as easy. Key Lakes is the member holding coverage for all GLF vessels.
Full P&I and H&M cover may be a requirement of financial institutions if any lending instruments are in place for any vessels in the fleet. Being self-insured during the winter navigation experiment makes sense, as it is possible H&M clubs may have denied coverage due to high potential for claims. Since GLF has changed hands several times and is now managed by a true shipping company, it seems likely they would have true H&M coverage.
Quick clarification, P&I (Protection & Indemnity) coverage is for claims related to damages caused by the vessel. Damage to docks, oil spills, damage to other ships, and the like. It could be compared to comprehensive coverage for your auto. H&M (Hull & Machinery) is for damage to a ship. Hull repairs after grounding, machinery faults which are high value to repair, and others. It is not a fixed line, though. Many claims can be assessed to both P&I and H&M depending on the situation. P&I is a general term taken to include both, as P&I clubs also offer H&M coverage. It is common for shipowners to have one club for P&I and a different club for H&M.
Also, P&I clubs technically are self-insured. A good analogy would be to a "farmer's co-op". Members are the shipowners and money (premiums) are paid in to a collective fund and disbursed as claims are filed. The clubs all work together and will share claims as well.
Some further information can be found here https://www.igpandi.org/about
My apologies for taking away from the original discussion.
