Anderson Color
Guest Who
Re: Anderson Color
Assuming you mean hull color, as I mentioned in another post, the best match for this would be to use Duplicolor automotive red primer with a clear coat of lacquer or gloss or semi-gloss clear enamel. Nothing in regular model paints (Testor's) is even close to ore red.
Anderson Color
What brand (Testors?) and color would be used in a model of Arthur Anderson? TIA
