Zincs
Re: Zincs
Mr Link wrote: January 28, 2026, 12:12 am Anodes are applied to many Great Lakes vessels, but I believe that magnesium and/or aluminum (or magnesium or aluminum based alloys) are the materials primarily used for fresh water vessels instead of zinc. Here is a link to a photo of GLT's tug Colorado showing it out of water with numerous anodes around its stern. Photo by Dennis O'Shea, posted to the Fans of the book Know Your Ships Facebook page in 2024. [url]https://www.facebook.com/photo?fbid=102 ... 2882491181[/url]
We use them on pleasure boats.. especially inboard outboard aluminum drives but also prop shafts rudders etc. stops dissimilar metal corrosion. But the main culprit is leaking stray currents from poorly maintained boats with bad grounds hooked to ac shore power. Aluminum or magnesium in fresh water. Zinc doesn’t work as it turns passive n clouds over. All outboard motors have them now.
Guest_SB
Re: Zincs
Unread post by Guest_SB »
Long winded reply coming...
The "zincs" are what's is known as sacrificial anodes. They are used to protect the steel (or aluminum) structure of a vessel.
The anode is made a of a metal which is more reactive (See galvanic scale: https://www.mfcp.com/technical-info/galvanic-corrosion) than the metal being protected. Steel hulls typically use aluminum anodes, aluminum hulls use magnesium. Both types used to use zinc as the anode material, but it is less friendly to the environment and has lost popularity - not legal in some waters.
I may not get all the technical terms exactly right, but electrolysis takes place when metal is in water where the metal oxidizes (rusts) - it loses electrons. The sacrificial anode on a boat is essentially the weak link. It will lose electrons more easily than the base metal and protect it from oxidizing until the anode has wasted away.
This is much of a problem in seawater where the salt speeds up the process. Similarly the warmer the water the faster it takes place too.
On the Great Lakes this isn't a huge problem, but anodes are used particularly around the stern of the vessel. At the back of the boat there are usually propeller shafts, rudder shafts and propellers which are made of stainless steel or bronze alloys. Both those metals are further down the galvanic scale and, if unprotected by a "zinc" the hull steel would become the anode and corrode more quickly.
Zincs are installed in a variety of places onboard a vessel, not just the outside of the hull. They're typically found in ballast tanks (seawater mostly), inside seachests, inside piping systems, etc. Anywhere that there's risk of corrosion - a bunch of sacrificial anode are much cheaper to replace than a hull!
Re: Zincs
What is the purpose?
algowest
Re: Zincs
Unread post by algowest »
Confirmed anodes use used on Algoport & Bristol Bay - photos attached.
Re: Zincs
Re: Zincs
Had to do a search for this, as I'm well aware of the mineral supplement but never knew about the partnership in preserving boats, ships. A video can be found on YouTube.
Zincs
Was on a drydock tour of the USS New Jersey and about the back of the engineering spaces the hull had a lot of Zincs. Granted salt water vs freshwater, but are zincs used on any great lakes vessels
My guess is Canadians who go to salt water. And probably Coast Guard units
