Ocean Tower is back…
Re: Ocean Tower is back…
Awesome journey and a great job reporting the progress. Thank You.
Steamboater66
2146h EDT Thurs. Aug. 13/26
Checked for the Ocean Tower big blue crane p-82. They have reached Pearl Harbor, Hawaii.
In fact if they met the tracker stated time of 1423h. Mooring has likely just taken place. Congrats to Dann towing and the tug crews who made this happen.
Steamboater66
1107h EDT Thurs. August 6/26
The Ocean Tower continues on a course of 259 deg. at 6.8 knots. Her basic position is 30 deg. N lat. x 127 W Long. Their local time now is -7h to US mainland.
Temperature is 19 - 21 C. Winds are NW moderate NW at 10 - 20 kts. Sea swells are running 1.5 - just over 2 metres.
Steamboater66
0114h EDT Thurs. Aug. 6/26
Ocean Tower’s position at this time is 30 deg. N latitude and 127 deg. W longitude. The tow is moving at pretty well maximum safe speed of 6.8 knots. By my rough calculations the tow is around 600 miles west of San Diego.
Feel badly that the security system that is part of the Boatnerd posting protocol has for some reason been rejecting my posts for the last 5 days or so! I am still following the tow. Hope folks are still following this historic for our times event as well
Guest Paul A
Unread post by Guest Paul A »
Hope you get back in Steamboater66, I look forward to your reports!
Currently cruising at 6.8kn, 259°, location 30°45'N, 128°1'W and a long way to go.
BNVolunteer
Unread post by BNVolunteer »
Steamboater66,
Received your message from Monday morning stating you were having trouble posting here. Please try again. I suspect it was an issue with either the PHP forum software or the hCaptcha security software, which Boatnerd cannot troubleshoot. It must be working sometimes since your Monday morning message came through, and if you are seeing this message, I posted it as a guest, without logging in.
Thanks
Boatnerd volunteer.
Thanks for all your updates
rcrvrp
Unread post by rcrvrp »
Is it now on its direct route to Hawaii? No more land in sight till then?
Steamboater66
00:00h EDT Fri. July 31/26
Ocean Tower has been on the move.Friday, July 31/26 she is at sea some 200 nm off of San Diego. Ships time would presently be just past 2100h PT. Departure was on Thursday. I have not been able to locate the exact time. As there are
No land bodies within range weather-wise; I have no meteorological sources. I know they are on a 259 deg. course making 6.1 kts. Latitiude 32-01.659N/Longitude 120-33.94W.
Steamboater66
0850h EDT Mon. July 27/26
ARRIVAL!! Ocean Tower and crane 82 are approaching their next destination point San Diego. They left Manitowoc WI on May 29 to deliver this crane to the naval base in Hawaii. San Diego will allow the tug to be re-supplied, fuelled, and for the crew to have some long-awaited rest.
Steamboater66
0005h EDT Mon. July 27/26
With a 2kts W wind and a 331 deg. course Ocean Tower and blue crane 82 are about 60 nm offshore of Ensenada. THEY have 65 -70 nm to cover to reach their next major stop, San Diego. ETA there is 0600 h Monday ( TODAY).
They are sailing at 7.1 kts under a clear sky. That 2 kts breeze is creating 1.2m of wave action from the SW. Rest, replenishment of food and supplies, and refuelling will likely take 2-3 days. The run to Hawaii is 2400 - 2500 nm.
Steamboater66
2126h EDT Fri. July 24/26
On a 316 deg, course, the blue crane tow continues the generally northward track to San Diego, their next stop before making the turn westward toward the ultimate destination of Hawaii.
Ocean Tower is making 5.8 kts. A steady breeze out the W has seas of 1.8 m crossing her path from the SW.At this time they are abreast Isla Natividad. The sailing distance remaining to San Diego is 360 to 400 nm. Tonight’s temperature is 28 C.
Steamboater66
0028h EDT Fri. July 24/26
The compass has swung even more toward North…330 deg. at this hour!. Remrember ETA San Diego is July 27…just 3 days off.
Speed tonight is 6.6 kts. The closest weather land reference point tonight is Pueryo Alfredo Lopez Mateos in this rather sparsely populated, remote Baja region
The wind is NW 8 kts and steady. The seas are running from the SW. wave activity is cresting at 1.2 m.tThe temperature is 25C. I would estimate the distance to San Diego to be 450 - 500 nm.
Steamboater66
2358h EDT Wed. July 22/26
Ocean Tower’s course has taken a few more degrees of a northerly direction. Tonight they are on a 319 deg. course.as they make their way through the 650-700 nm run to San Diego for arrival July 27.
Tonight they are making 6.8 kts under partly cloudy skies. The wind is NW 8 kts gusting 11. Waves from the SW creating wave action to 1.8m. On the map they are 45-50nm at sea abreast of Punta Pescadero State Beach, Mexico.
Steamboater66
2400h EDT Tues. July 21/26
Ocean Tower is making 6.8 kts on a 307 deg. course tonight under overcast but rain-free skies. She is just NW of the Islas Maria island group and will be coming off the tip of the Baja Peninsula in another 250 nm. Winds are NW at 13 kts gusting 15. The sea surface has waves out of the SW at 1.8 m.The air temperature is 31deg. c. The current ETA San Diego is July 27. The estimated sailing distance to San Diego is 750 - 800 nm.
Steamboater66
0033h EDT Tues. July 21/26
Ocean Tower and that huge crane are under cloudy rainy skies again tonight as they glide NW on a 301 course at 7.1 kts. They are about 60 nm off Ipala on Mecico’s West coast. Ipala looks about 200-300 miles south of Puerto Vallarta.
A whisper E wind is steady at 2 kts. The water is almost still with scarcely a ripple at 0.5m of activity. The temperature is 31C. The next port call will be as I predicted, San Diego. The sailing distance into SD is 1 000 nm.
Steamboater66
Re: Ocean Tower is back…i
0052h EDT Sunday July 19/26
Ocean Tower is proceeding on a course of 291 deg. at 6.8 kts. She is almost 50 nm at sea off Acapulco de Juarez, Mexico. It is rainy. The wind is WNW at 5 kts, gusting 7. Seas are running 1.5 m out of the SW. The air temp is 27 deg. C.
Steamboater66
.1258 h EDT .Fri. July 17/26
On a 290 deg. course, Ocean Tower continues northward. The north wind is blowing 8 kts out of the N.at 5 kts and gusting 8.The tow is making 7 kts.The arrival date Hawaii is July 27. No sea data is available.
Steamboater66
1032h EDT Wed. July 15/26
Thanks Guest rcrvrp for getting on here, your thoughts and questions….
This morning the tow is running a 291 deg. course about 45nm off the W coast of Guatemala coming abreast Guatemala City which is about 50 nm inland in a sparsely populated region.
Other than basic meteorological stats; could not find sea conditions info…very remote!
They are located generally at 40 deg. N and 21 deg. W. They are making 7.7 kts under broken skies in a temperature of 19-22 deg.C. Winds are out of the N at 4 kts gusting 8.
As for your thoughts-questions…
I imagine crew might be round 6 or 7. A captain, engineer, cook if lucky, and others for wheeling and/or on deck jobs.
Probably fair sized refrigeration locker, smallish quarters, galley-dining table, and toilet-shower.Watches could be 6h on.
I think I saw that she’s got something like 96k gal. fuel cpty.
As for tow speed 7.5 kts is about max. safe with this monstrosity lurking aft.Sea and wind are real big concern always!
I see they have an ETA Hawaii of July 23.
rcrvrp
Steamboater66 wrote: July 13, 2026, 10:04 am 1058h EDT Mon. July 13/26
Just checked mileage from Panama City to Hawaii. It is a great challenge to be covered. Also very humbling…4 800 to 5 100 nautical miles. Statute mileage is 5 100 to 5800 miles. Yikes!!
Just rough figuring that would be 3 weeks at 10 knots 24 hours a day. Holy cow! Can they do 10 knots? Do they have the ability to crew the boat around the clock for 3 weeks? Food and fuel for that long? Resupply by ship? So many questions come to mind.
