Bow wheel
BigRiver
Re: Bow wheel
Unread post by BigRiver »
From Know Your Ships
Screen Shot 2020-07-03 at 7.44.48 PM.png (82.85 KiB) Viewed 3551 times
Re: Bow wheel
I don't recall the barge Chief Wawatam ever having the symbol painted on, but that was quite a while ago. It did have a bow thruster installed in 1999.
Re: Bow wheel
Guest wrote:I assume its not required as some ships don't have the symbol but have bow thrusters
I seem to recall these beginning to appear at some point during the 1990s. I'm assuming that it was due to some type of regulation requirement or liability reasons. Which ships with bow thrusters don't have the painted symbol?
Re: Bow wheel
Do you have any examples.
Re: Bow wheel
Re: Bow wheel
Thanks for that!
Bob
Re: Bow wheel
Unread post by Bob »
It means they have a bow thruster to help maneuver they front of the ship.
Re: Bow wheel
It designates the location of the bowthruster.
Bigboat
Re: Bow wheel
Unread post by Bigboat »
Bow thruster.
Re: Bow wheel
custom500 wrote:Many of the ships have what looks like a four-spoke wheel painted on each side of the bow. What does this denote?
Indicates the presence of the bow thruster.
Re: Bow wheel
A bow thruster. If they have a stern thruster it will have the same symbol.
navarch
Re: Bow wheel
Unread post by navarch »
This symbol shows where bow/stern thrusters are. Helps make boaters, dock workers, etc. aware of where they are to avoid any accidents from the wash/suction.
Re: Bow wheel
This a the symbol for a bow thruster, the bow thruster is directly underneath that symbol. It helps tugs when docking a freighter to know where it's safe to push from.
Pazzo
Re: Bow wheel
Unread post by Pazzo »
I believe what you are referring to is the hull marking for the bow thruster location. It's a similar concept to naval jets having the "caution: intake" warning painted on the front sides of jets.
Re: Bow wheel
These symbols are there to bring attention to the fact that the ship has a submerged thruster unit. Ones at the bow denote a bow thruster while those at the stern a stern thruster unit. Many ships now have both.
JMarx
Re: Bow wheel
Unread post by JMarx »
I'm not a sailor but believe you are referring to the indicator of the bow thruster location below the water-line...
(image in Wikipedia: https://en.wikipedia.org/wiki/Manoeuvring_thruster)
Re: Bow wheel
It indicates there is a bow thruster so stay clear
Re: Bow wheel
I believe you may be referring to the ship’s bow thruster symbol as most all ships have what you described. Some even have a stern thruster as well thus the symbol would also appear both at the bow and the stern. Hope that this helps to answer your questions.
Re: Bow wheel
Unread post by Darryl »
Bow Thruster! It is a safety notification to all those who could be effected by the bow thruster when in use. The bow thruster could quickly draw or send water in different directions when it is used to nudge the bow of the boat to the left or right.
custom500
Bow wheel
Unread post by custom500 »
